Drag Racing Tech
Can you be consistent/competitive with ratchet shifter?
Old Mar 3, 2014 | 07:41 AM
schmendog's Avatar
Default Can you be consistent/competitive with ratchet shifter?
Deciding on if should buy a pro shifter or a ratchet shifter for my TH400. It's a street/strip car, should be a mid 9 second car after I get done with the new build. I like ratchet shifters much better but want to know if there are any downfalls with them at the track? Is a pro stick any quicker at shifting gears etc.
Old Mar 3, 2014 | 01:05 PM
StangEaterSS's Avatar
Only experience I have had with them was a B&M ratchet on a customer car and the thing was junk. At times it would skip a gear other times it seemed like something was binding up. I replaced it for him w a B&M gated shifter. Shifts flawlessly now. I run a TCI outlaw gated shifter in my own car. I love it.
Old Mar 3, 2014 | 06:13 PM
N2RACINGLS1's's Avatar
This ^^^^^
I had the same shifter slow on the shift causing the engine to hit the rev limiter. Switched to the B&M Pro shifter and it has worked perfect for 5 years.
N2
Old Mar 4, 2014 | 08:41 PM
schmendog's Avatar
Dammit I was hoping Id hear the opposite results.
Old Mar 4, 2014 | 09:13 PM
studderin's Avatar
skip gears?
missing gears?
slow shifting?
silly auto shifters
Old Mar 5, 2014 | 04:43 AM
Doug G's Avatar
B&M Mega shifter here....you could hit with a hammer and only goes 1 gear at a time....as long as you hit your shift points right and get a consistent launch....why wouldn't it run the dial-ins ?
