Drag Racing Tech
too tired to search LS1.com
Old Nov 16, 2001 | 10:43 PM
java's Avatar
From: no stops signs, no speed limits .... on a highway to hell
Default too tired to search LS1.com
help me do the math guys, it has been a long week .... can a set of 15 x 10, 5'' rear spacing, 4.5'' bolt circle tires fit under a T/A? Would I need to narrow my rear end (on the car that is), roll the fender .... what?
thanks
Old Nov 16, 2001 | 10:49 PM
McRat's Avatar
Default Re: too tired to search LS1.com
I'd say... No way. I have 7.5 wide with 5" BS and they touch the lip on bumps. Yours will stick out 2.5"... You'll need mudflaps to avoid a ticket!
Old Nov 16, 2001 | 11:08 PM
95 Formula's Avatar
nope..a 10 inch rim needs 7.5 to tuck all the way under..and then you have to do some inner finder modification. Some use a 6.5 bs but I would guess you would need to roll the finder and still may have trouble if the car squats a good bit.
Tim
Old Nov 16, 2001 | 11:56 PM
ChrisB's Avatar
6.5-7.5 is what you want for backspacing.
Chris
Old Nov 17, 2001 | 04:13 AM
Top Fuel's Avatar
It has to be a 4.75" bolt circle as well. <img src="images/icons/smile.gif" border="0">
later,
Steve
Old Nov 17, 2001 | 05:14 AM
SCZ28's Avatar
I have 7.5" BS and didn't need to modify the fenderwheels but it is a tight fit. YOu do need 4.75 bolt pattern to as was mentioned.
Old Nov 17, 2001 | 07:51 PM
Navy David SS's Avatar
I have a set of Convo Pros, 15x10, with 5" B/S. They stick out at least 1.5-2". Without the adjustable springs in back, they would not fit.
Have been looking for a set of wheels: 1) no grinding; 2) will fit a set of 26x11.5x15 tires; 3) I don't have to roll anything.
David
