To anyone with LCA relocation brackets.............
Thanks,
Jeremy
Bolt in's are O.K. if your doing the mod and don't have a welder. As soon as your done putting the car back together with the bolt in's take the car and get them WELDED in place. The area is just to much of a high stress area not to welded the relocation brackets in place.
Global West also make a nice set of weld in's that can be adjusted as needed. These might be worth a look too.
They also recommended doing the air bag in the right rear the same time as doing this, after all your in there might as well. I think most say try the air bag at 15 lbs starting out.
I'm sure some other will chime in...
