Drag Racing Tech
OK,how many have sheared wheel studs...
Old Jan 6, 2002 | 06:36 AM
jfm's Avatar
jfm
Default OK,how many have sheared wheel studs...
when using Weld nuts?
I lost 2 more yesterday on the same rear wheel.I have snapped 2 on the front and 2 on the rear before this.
Anyone have better luck using a diff lug other than Welds? I use great care to make sure each one is hand started and easy to turn.TIA
Old Jan 6, 2002 | 09:28 AM
Smoke_ur_5.0's Avatar
Default Re: OK,how many have sheared wheel studs...
Sheered all 5 on my drivers side of the moser 12 bolt with the Weld lugs,weld wheels and ET drags26x10x15's.
[ January 06, 2002: Message edited by: Smoke_ur_5.0 ]</p>
Old Jan 6, 2002 | 09:34 AM
GeorgeC's Avatar
I sheared all five on the driver's side one night at the track just after I launched the car. The wheel came completely off, but luckily stayed inside the fenderwell so nothing was damaged. Pretty scary... That was using 12mm studs and Weld shank lugnuts.
In my case, I think the main cause was not checking the tightness of the lug nuts often enough. I believe they had worked themselves a little loose. I make it a habit now to retorque them every 3-4 passes or so.
I'll probably switch over to 5/8" studs in the future so I can ditch the shank lugnuts all together.
Old Jan 6, 2002 | 06:26 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I torque my wheels every time I drive the car. And before any track passes.
Old Jan 7, 2002 | 12:22 AM
TwoFast4Lv's Avatar
One of the reason's I fear Weld wheel's They work best with 5/8ths stud's BTW
