Drag Racing Tech
Sealing motor plate
Old Jan 21, 2015 | 10:21 AM
TAHOE5.3's Avatar
Default Sealing motor plate
How are you sealing the drivers side of motor to the plate? The head overhangs slightly and the motor plate hits the head before the block.
Old Jan 22, 2015 | 12:41 AM
Blown06's Avatar
8 Second Truck Club
With a water pump gasket
Old Jan 22, 2015 | 06:27 AM
TAHOE5.3's Avatar
Thanks. Didn't know if I might have to double up
Old Jan 23, 2015 | 12:52 AM
Blown06's Avatar
8 Second Truck Club
Also, if you use a water pump gasket and the plate also bolts to any other holes in the block, you'll want to space those out an even amount as well so as not to put the plate in a bind. I'm sure you know this, but just wanted to remind.
1 water pump gasket should suffice.
Old Jan 23, 2015 | 10:04 AM
TAHOE5.3's Avatar
Gotcha
Yeah my fab guy has limited LS experience so he's being extra careful with anything that he doesn't like the look of.
Old Jan 26, 2015 | 07:59 PM
ATwelveSec02Z28's Avatar
my plate is milled down in that area to clear the head...
