Some cam help for my setup...
As of now I have trick flow 215 heads with a fast 102/92 setup with TSP 1 7/8 headers and other bolt ons and stuff with a slp 51014 cam (236/236 .590/.590)
Iv had some ideas to maybe change out my cam to something more "tried and true" maybe (and to be honest it doesn't even sound like it has a cam most of the time when warmed up)
Iv recently came across a friend wanting to get rid of an MS3 cam (237/242 .603/.609)
If not a good choice, what would be good a good balance of duration to lift with trick flow 215s? Iv heard very mixed reviews on the very few feedback on the current cam I have.
I was seeing if I could get some input with some good guys about the change? I see the ms3 has a tad more duration, and a lot more lift, would it be worth a change? I'm looking for more track times and spirited street driving more than dyno numbers. The car is also an M6 with 3.90 gears if it helps at all.
Thank for reading!!
I think the one with the 111 LSA is the one you want. I think it's a great nitrous cam as well.
Get you the PRC .650 double spring kit to go with it.
Can't remember but you may have to flycut your pistons.
Do some research.
