Drag Racing Tech
Was front air pressure do you recommend
Old Jan 9, 2002 | 06:56 PM
FormulaWS6's Avatar
Default Was front air pressure do you recommend
in 17 WS6 tire when running 16 inch ET Streets in the back? I have heard that you should lower the pressure a little due to the low pressure in the rear to help the car from swaying back and forth.
Also, do you guys burnout with an A4 in just D or do you put in 2nd gear? In the past I have left in D and was able to do good burnouts. Thanks..
Old Jan 9, 2002 | 08:02 PM
WILWAXU's Avatar
Default Re: Was front air pressure do you recommend
50psi! <img src="gr_images/icons/wink.gif" border="0">
Old Jan 10, 2002 | 05:38 PM
AZLS1's Avatar
I run them at the highest tire recommended PSI to decrease rolling resistance.
The sway is really scary on the top end with the sway bars removed! <img src="gr_grin.gif" border="0">
Sterling
Old Jan 11, 2002 | 10:45 AM
Ragtop 99's Avatar
I do my burnout in 1st gear. I don't want the tranny shifting during this process. I bring it up to 5500 rpm and hold it there.
I pump my front tires up to 40lbs, if I remember.
