Tick Battery Relocation Kit
1 gauge from switch to starter
2 gauge from starter to fuse panel
2 gauge from alternator to switch
2 gauge engine ground
1 gauge battery to switch
1 gauge battery ground
battery tray and hold-down
battery box or bulkhead
switch (I'd use a push pull)
miscellaneous connectors etc.
go ahead and add up the parts
It doesn't save any weight at all and I doubt it makes any difference with traction. Unless you have removed about 50 to 100 lbs. from behind the rear axle.
Spend your money somewhere else or on a light-weight battery.
The only problem I see with a light weight battery is a big accessory loads (big stereo or aux lighting) or lots of short drives with long parking times.
1 gauge from switch to starter - Don't need
2 gauge from starter to fuse panel - Don't need
2 gauge from alternator to switch - Included in kit
2 gauge engine ground - don't need
1 gauge battery ground - Included in kit
battery tray and hold-down - Included in kit
battery box or bulkhead - Not needed. Battery box is metal.
switch (I'd use a push pull) - Flaming river is $69. Moroso sells some cheaper
It's not all about losing weight. It's also about weight bias. Who wouldn't want to move 36lbs off the nose and put it over the right rear tire?
-Mark
-Mark
. However I am thinking of a light weight battery. Spending money on other stuff right now. For me, battery relocation is low on the to do list. https://ls1tech.com/forums/attachmen...1233334884.jpg
. However I am thinking of a light weight battery. Spending money on other stuff right now. For me, battery relocation is low on the to do list.I did the light weight (dynabatt) battery for a year or so. It did save me about 20 lbs but since it's much smaller, the reserve on it is 5 mins if you are lucky. Meaning between rounds if you turn the fan on or have an electric water pump it will drain the battery fast as hell. I had to jump mine on more than one occasion. I went back to a full size battery and moved it to the rear.
I have mine wired like this: 1g from dist box to switch. 1g from alt to switch. Removed wire from alt to dist box. 1g battery to ground. 1g battery to switch. Didn't mess with the starter at all.
I will say that everyone should put in a 150amp fuse between the battery and the alternator. As close to the battery as possible.
I also added 90lbs of ballast in the rear one time and I ran quicker due to a better 60ft. Adding weight doesn't always mean you'll run slower.
Plus putting the battery in the rear cleans up the engine bay a little.
-Mark
https://ls1tech.com/forums/attachmen...-trunkbat3.jpg
...and the biggest problem with f-body cars is weight. mustangs have about a 500-600 lbs advantage. moving weight to behind the axle isn't a big concern for me, removing weight is and keeping the car a reasonable street machine is.
I do agree that it does clean up the engine bay..
