Drag Racing Tech
help with hooking dr's on the bottle
Old Mar 24, 2015 | 08:28 AM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
You want your rear control arms to run up hill towards the body.
Old Mar 24, 2015 | 02:52 PM
93camaro_zzz's Avatar
Originally Posted by transampetews6
stiffer rear shocks, 2nd on MT pro at 20 psi.
pinion angle is to much. there isn't that much defection in the torque arm that you need -2.5 degrees. I run about -.5 degrees. although I doubt that has anything to do with traction.
THis is a good answer. The MT pro will probably solve your problems altogether. But my buddy had a similar setup to you, he was about 430-440whp with TH400, 275 MT pro, 4200 stall, and about a 125 shot.
Without using his transbrake, we found the best idea was to have the window switch set at 2800rpm. Then he would just mash it off of idle, and it would sixty a 1.43 almost every time. He just had CE shocks also set on 50/50.
Old Apr 10, 2015 | 08:59 PM
TravisMcGill2000's Avatar
Swapped to a mt 28x10.5 full slick and still spinning. 1.44 60ft is best I could get. Tried 14, 15, 16 air pressure. With the best 60ft at 14. It seems to spin after the front starts to come back down.
Old Apr 10, 2015 | 09:33 PM
Old Apr 14, 2015 | 02:33 PM
T6Rocket's Avatar
It comes up awfully quick, then settles back down just as quick. Maybe the fronts are too loose?
Al
Old Apr 14, 2015 | 04:12 PM
Tr rocket I believe you right. I was 2 clicks from from loose there. Gona try them at 5 next time out.
Old Apr 14, 2015 | 10:30 PM
stherngent's Avatar
Ive run mine for 2yrs and have had better hook up on DR at psi around 25-27 just my .02 cents.
Old Apr 14, 2015 | 10:51 PM
Zmg00camaross's Avatar
Front is to loose, tighten it up, I like the front end to be about 26 inchs at the fender if you measure from the center of the wheel, so 26 inches from ground to fender lip, control arms in bottom hole, just seems it like to unload the rear off the hit.
Old Apr 14, 2015 | 11:06 PM
Heyfred's Avatar
Reduce pinion angle to 1.5, measure from bottom of rim lip (closes to the ground) to fenderwell, set to 23". What is your instant centerheight? Can't help with your shocks. I run my Afcos, 12 compression, 30 rebound.
Old Apr 14, 2015 | 11:29 PM
thanks I will tighten front up few clicks. Im settin at 26in from ground to center of finder lip. Got 28.5 in the rear.
Old Apr 14, 2015 | 11:32 PM
Thanks for your input. Ive havent measured my instant center height. I plan on buying some afcos or viking within the next few weeks.
Old Apr 26, 2015 | 02:18 PM
  #32
May have found my problem. My anti roll bar will move side to side. It will move shock to shock. Gona order some new mounts monday.
