Drag Racing Tech
Paging Joe Kizzire
Old Jan 25, 2002 | 06:58 AM
2000 Camaro SS's Avatar
Default Paging Joe Kizzire
Nine Ball said this
"Or you can do what Joe Kizzire did, he had his reared narrowed to fit the deeper offset rims and it looks great. He ordered the reared that way. He has the Convo-Pros also.
SS, you need the 15x10 Draglites or Pro Stars, with the 7.5" backspacing. Those work great with the slicks you listed.
Tony "
You can see the thread here.
Can you tell me about your rear end please. 12 bolt, 9 inch, Moser, Strange. What is the specifications you used to have it built? What is the biggest rim/tire that cam be run? Finally what tires are you running?
Old Jan 25, 2002 | 07:15 AM
Joe Kizzire's Avatar
Resident Grump
Default Re: Paging Joe Kizzire
My rear is narrowed a total of 3 inches from stock... 1 1/2 inches from each side. I use Convo Pros 8 1/2 wide with 5 1/2 backspacing with 28x9
ET Drags. If you run a 10 inch rim go with the
6 1/2 inch backspacing.
Old Jan 25, 2002 | 07:56 AM
[quote]Originally posted by Joe Kizzire:
<strong>My rear is narrowed a total of 3 inches from stock... 1 1/2 inches from each side. I use Convo Pros 8 1/2 wide with 5 1/2 backspacing with 28x9
6 1/2 inch backspacing.</strong><hr></blockquote>
With the a 3 inch narrowed rear and 10 inch rims w/6 1/2 backspacing I would not rub on the inside of the wheel well?
