Drag Racing Tech
What does it take to go 8's?
Old Jun 6, 2004 | 12:17 PM
NJSPDER's Avatar
well, it takes a lot for you and the car.
besides all teh nhra safety stuff you are gonna have to find a wya to get the weight of the car down. no offense gang, but 4th gens are sort of pigs. the basics of gutting teh car will make your life a ton easier. some race classes require a "full interior" which means there is gonna be a good amount of weight in carpet and dash and stuff that you can't get rid of.
for the chassis you will have to decide if you wanna go with a "stock" suspension or if you want teh car back halved. stock is actually teh easier/cheaper option. all you would have to do is go through the after market offerings and grab teh lightest/strongest/best geometry version of everything. back halving a car costs a ton of bread and has to be certified.
the motor is the biggest expense. it takes a bunch of power to go that fast. adn as we all know, power = $$$$.
tranny is pretty easy, a built th400 or pg should be abel to take care of it.
later
tim
Old Jun 6, 2004 | 12:25 PM
FASTFATBOY's Avatar
8 second slip=cubic dolla's
David
Old Jun 6, 2004 | 01:07 PM
andy98Z's Avatar
About 50,000 w/ LS1 Turbo F-Body.
Old Jun 6, 2004 | 02:40 PM
taqwache's Avatar
Originally Posted by TXLSS
You want f-bod 8's? Yank the LS1, put in a Reher-Morrison or Shafiroff mountain motor, add nitrous and susp., enjoy. Oh yeah, cut the hell out of the engine bay, too.
**** with a BBC all you need is a merlin tall deck 4.5" bore block, eagle 4340 4.5" crank, good rods and pistons, $3k heads and a fogger. put it in a leaf sprung f-body like a '79 model and take out a crap load of weight. can all be done for less then $10,000 if done all by your self and you got an 8 second car that will last a whole lot longer then a 8 second LS1.
Old Jun 6, 2004 | 08:36 PM
NumberOneSled's Avatar
I meant with an LS1
Old Jun 6, 2004 | 09:17 PM
silverbeast's Avatar
less than 10,000??? i dont think it would be that cheap. if it was everyone would be going that route.i know i would.
Old Jun 7, 2004 | 09:52 AM
taqwache's Avatar
well it might be alittle bit more but if you do every thing completely by your self and use a cheap 79Z to work with it could be done. its not really that hard with a 572CI BBC with the right heads and nitrous on top. i even heard of people doing it with the stock 8.5 10 bolt those cars have.
Old Jun 7, 2004 | 10:33 AM
FASTFATBOY's Avatar
You might do it for under 10K, but I dont see it, oh yeh remember to pull the pin on that grenade when you turn the top bulb on when you make your 1st pass.
David
