Drag Racing Tech
16" Weld Pro-Star rears
Old Feb 6, 2002 | 12:23 AM
WJ SOM SS's Avatar
Default 16" Weld Pro-Star rears
Question. Just purchased a set of 26x11.5x16 ET streets for my '02 A4 SS. Is Weld's 16x9, or 10 the correct wheel w/correct backspacing for my car? Do I need a 7" backspace wheel? I have a set of 16" SLP Pontiac take-offs, but would rather run something better looking & lighter, if possible. I already have Weld Pro-Star 15x31/2 fronts & 5/16th's spacers. I don't want the rears sticking out, if you know what I mean. Any help appreciated. Thanks. WJ.
Old Feb 6, 2002 | 12:27 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: 16" Weld Pro-Star rears
In this pic, taken two years ago, I had 16x9 Draglite XPs. They were 6.5 backspace. I had 11.5x26x16 ET Streets on there and I cut a 1.57 and could have done even better with them.
You planning to get regular Pro Stars or XP's?
Old Feb 6, 2002 | 12:34 AM
WJ SOM SS's Avatar
Hi John. I already have the tires, (rears) I already have the Pro-Star fronts. Are the Drag-lites better, lighter? What is the correct Draglite (rear)? What is the correct 16" Pro-Star rear? Appreciate your help. WJ. <img src="images/icons/confused.gif" border="0">
Old Feb 6, 2002 | 12:41 AM
LS1Tech Co-Founder
Weld makes Pro Stars and Draglites in the XP series.
XPs:
-no grinding of calipers
-but weigh as much as stock, 22-23 lbs
-slightly different face
-use different lugs than regular ones.
Regulars:
-I think you need grinding even with spacers for 16s.
-Weigh 12-13 lbs.
Old Feb 6, 2002 | 02:39 PM
WJ SOM SS's Avatar
Thanks John. Too bad Weld really doesn't make correct backspacing whls for the 4th's. Think I'm going to start over & go with 15" Centerline Convo-Pros. Thought women were the ones who always keep changing their minds....Again, Thanks. WJ. <img src="gr_images/icons/wink.gif" border="0">
