Drag Racing Tech
5 pt. Harness.....Help!
Old Feb 11, 2002 | 10:11 PM
Jantzer98SS's Avatar
Default 5 pt. Harness.....Help!
What do you guys recommend? Is the Cam-lock feature worth it?
And how did you install the crotch belt and the rear belts? Would a Y-style belt be easier to install the rears. If it makes a difference, I have the Wolfe 6pt. Cage.
Thanks,
Scott
Old Feb 12, 2002 | 01:08 AM
Mike Morgan's Avatar
Default Re: 5 pt. Harness.....Help!
[quote]Originally posted by Jantzer98SS:
<strong>What do you guys recommend? Is the Cam-lock feature worth it?
Thanks,
Scott</strong><hr></blockquote>
Scott,
Give me a call tomorrow after 4pm PST. I'll get you hooked up on the belts and let you know how to hook them up.
Old Feb 12, 2002 | 01:18 AM
Onyx LS1's Avatar
Post what you find out. I need to know the same thing. <img src="gr_stretch.gif" border="0">
Old Feb 12, 2002 | 03:33 PM
mmiller's Avatar
Texas Director
I also need to know this.
Old Feb 13, 2002 | 12:58 AM
SCZ28's Avatar
The cam lock is worth it if you want less hassle and have $100 extra to spend. Depending on what type of seat you have a "y" or "v" will work better.
As for the submarine belt, I just bent some metal channeling and installed it under the front seat bolts.
Old Feb 13, 2002 | 01:16 PM
Onyx LS1's Avatar
I just bought a 5 way cam-lock y-type wrap around style Simpson harness. I hope it works well! <img src="gr_stretch.gif" border="0">
Old Feb 24, 2002 | 03:16 PM
SSValet's Avatar
Do these work with the stock seats?
Old Feb 24, 2002 | 05:33 PM
chevyguy3's Avatar
i just have a normal latch style RJS harness. i went for the normal latch since im cheap, and it didnt bother me at all as my everyday driver. i got the lap belts that have clip ends on them and anchor bolts that go through the floorpan. for the shoulder harness i got separate wrap around belts since my seat sits right against the cross bar on the cage. i tried a bolt on y-harness and a wrap around y-harness and just couldnt make it work. i have a wrap around crotch strap. look at Wolfe's site, they have a nice crotch strap bracket for $35. its very easy to copy yourself if you want to save the $
Old Feb 24, 2002 | 05:35 PM
chevyguy3's Avatar
[quote]Originally posted by SSValet:
<strong>Do these work with the stock seats?</strong><hr></blockquote>
yup. and per the NHRA rulebook, if you are using a stock seat you can route the crotch strap in front of it, instead of through the seat as you would have to in any aftermarket seat
Old Feb 24, 2002 | 08:56 PM
SSValet's Avatar
Cool, thanks!
