Drag Racing Tech
cage question?
Old Feb 14, 2002 | 09:48 PM
B18B1LS1's Avatar
Default cage question?
Will a six point cage eliminate the need for sub-frames? Also, does anyone know how much lighter chromoly is over the mild-steel?
Thanks
Old Feb 15, 2002 | 08:51 AM
CHRISPY's Avatar
Default Re: cage question?
Yes a weld in six point will eliminate the need for subs and the chromely saves about 25 pounds over mild steel.
Chris
Old Feb 15, 2002 | 09:24 AM
MADMAN's Avatar
LS1Tech Sponsor
I would not delete the subframes. We tie our bars into the subframes for rigifity and safety. I personally would not install a bar without subframes. They arent that heavy.
__________________
www.madmanandcoracing.com
225-343-9029
Old Feb 15, 2002 | 10:43 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
My understanding is that chromoly is 1/3 lighter?
Figure a 6 pt mild steel is 90lbs Madman?
Old Feb 15, 2002 | 11:47 AM
MADMAN's Avatar
LS1Tech Sponsor
A 6pt is about 90lbs. It is lighter and stronger.
__________________
225-343-9029
Old Feb 15, 2002 | 01:27 PM
B18B1LS1's Avatar
Madman, your saying you take another piece of bar and connect the cage to the subs through the floor or you just continue the cage longer through the floor to the subs?
