Installed Viking DA coilovers
Afco shocks actually have a retaining ring that keeps the upper spring cup attached to the shock shaft, and then holes in the spring cup where is allows the spring to be retained to the cup with cable ties for this reason. Nothing to worry about, just be sure that the upper spring cup seats properly when you set the car back down on the ground.
