Drag Racing Tech
scaled the car tonight finally
Old Sep 13, 2015 | 09:59 AM
Taubr Unit's Avatar
Default scaled the car tonight finally
So this is my first time scaling a car and im not 100% what or how to look at the readings. This is my 4th gen camaro with a turbo ls in it and me in it so true 100% race weight. Front end is pretty close to each side but the rear is way off for some reason. Only thing on that side is me obviously and my fuel pump. I never did set preload on my anti-roll bar so could that be holding the rearend from equaling out? Im not too sure on how to set the anti roll bar so maybe start there?
Old Sep 13, 2015 | 11:16 AM
matt94z's Avatar
Which bar do you have? To set it properly, you need to be sitting in the car or have someone about the same weight as you
Old Sep 13, 2015 | 11:18 AM
Taubr Unit's Avatar
MWC drag bar. I have a idea how to set like you mentioned but not 100% sure on exacts.
Old Sep 13, 2015 | 11:24 AM
matt94z's Avatar
I remember when I had mine set he only worked on the passenger side adjustment. I wanted to learn but had to be in the vehicle
Old Sep 13, 2015 | 11:56 AM
01ssreda4's Avatar
Ive always been told set it neutral then lengthen the passenger side one turn to preload. If you don't do it enough the car will still lift the driver tire more, if you do it too much mine starting pulling left on acceleration, and I think I've got it about right now finally. Seems to be a small window to get it right, either that or I just don't know what the hell Im doing
Old Sep 14, 2015 | 02:21 AM
TTur1996's Avatar
To set the ARB you need the driver in the seat. Jack the front of the car up in the middle with something narrow on the jack, just till the tires are barely off the ground. (They can't be touching the ground.) Floor needs to be very flat. Measure from the corner of the door jam to the floor. The pass side needs to be a sixteenth of an inch higher. Adjust ARB to achieve this. That's how you start off. Then when you are at the track. If the car goes slightly right. Extend the pass. side a little. if it goes left shorten the pass. side. Only the pass. side is adj. after initial set up.
Old Sep 14, 2015 | 06:58 AM
MADMAN's Avatar
LS1Tech Sponsor
You do not use the anti roll bar to set preload. With the car on the scales with the driver in it disconnect the anti roll on the passenger side. Run the drivers spring up at least a 1/2" higher than the passenger side. You are looking for 10 lbs more weight on the passenger rear over the driver. The car should sit level side to side. Then hook the anti roll up neutral.
__________________
www.madmanandcoracing.com
225-343-9029
Old Sep 14, 2015 | 01:51 PM
droksformula's Avatar
Writing this down, thanks for the pro advice!
Old Sep 15, 2015 | 05:32 AM
TTur1996's Avatar
Never said anything about setting shock preload. My statement was strictly for the ARB. It was for after the shocks were set and car was level. My bad since I didn't state this. Several posts stated they were not sure how to set the ARB. Every car I have done like this, goes straight as an arrow. And I learned it from Pro's.
Old Sep 15, 2015 | 06:14 AM
MADMAN's Avatar
LS1Tech Sponsor
I know the question was ARB settings and you should never use the ARB for preload. You need your corner weights correct then set the ARB neutral. Moving the drivers front spring up or down affects the weight on the passenger rear.
__________________
225-343-9029
Old Sep 15, 2015 | 07:00 AM
Taubr Unit's Avatar
I don't have coilovers so how else would I equal the weight out besides actually buying coilovers or adding and/or moving weight around?
Old Sep 15, 2015 | 07:36 AM
MADMAN's Avatar
LS1Tech Sponsor
Thats about the only way.
__________________
225-343-9029
Old Sep 16, 2015 | 04:05 AM
TTur1996's Avatar
We always move stuff around in the car to get the weights rite. Try not to add any weight, and don't change even preloads on the coil overs. If you add that much preload to the left front. What happens during the launch and the weight transfers to the rear? By setting the ARB with all four on the ground and all that preload on the left front. When the weight is transferred to the rear. Won't the car go lite again on the right rear? Thus pulling harder on the ARB on the right side and making it go right? Then at the big end, wouldn't that uneven preload cause the car to push right? Not trying to argue. Just trying to understand your way of doing things. I love all information. Any is always appreciated. Thanks
Old Sep 16, 2015 | 06:13 AM
MADMAN's Avatar
LS1Tech Sponsor
By running the driver front spring up you are compensating for the driver weight. By using the ARB for preload you are binding the chassis up. Thats when the car will try to dart upon lifting and braking.
__________________
225-343-9029
Old Sep 16, 2015 | 08:40 PM
TTur1996's Avatar
The only preload is 1/16th of an inch on the chassis. That's one landing on a hex turnbuckle. Just enough to compensate for the torque and flex. I was told this method years ago. And it has worked perfect every time. We put our preload on our coilovers to be the same in the front side to side, and the same side to side in the rear. Was told never to preload coilovers like that. If the wheels are off the ground during the launch, how is the weight staying applied to the right rear? Sorry but that makes no sense. And would that not be putting a twist in the chassis because there is 79lbs more pressure being applied in one corner? Sorry, I guess I just don't understand.
Old Sep 17, 2015 | 02:10 AM
Blown06's Avatar
8 Second Truck Club
Don't argue with the madman.
Old Sep 17, 2015 | 02:20 AM
Blown06's Avatar
8 Second Truck Club
...do you realize who you are arguing with? If it has a torque arm, the man walks on water.
Old Sep 17, 2015 | 03:22 AM
TTur1996's Avatar
Not trying to argue with anyone. Just trying to figure out how the car doesn't push with those adjustments. And I know he is very good at what he does. Otherwise, I would have never asked.
Old Sep 17, 2015 | 09:11 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
If the car goes straight and handles fine so be it... do what you do. There are other methods and do in fact use ARB preload... it is proven and working today. There are many ways to do things, not saying one is right and others are wrong. If the goal is achieved then carry on.
Old Sep 17, 2015 | 10:25 AM
imma_stocker's Avatar
How many ways to skin a cat
MWC and MADMAN both have very solid history and TRACK PROVEN results. They might not agree on everything but they both know what they are doing in their own ways.
Carry on with the tech for us ignorant folk.
