Higher stall, slower ET
I am not logging nor do I have my own tuning software. The car was tuned after the cam install, but was not retuned after I bumped the stall up.
If I remember correctly the shift points are set around 6200-6400.
I tried not to idle to much in the lanes if I could help it and I was running the fans while I waited. I will look into the high IAT and that ram air you mentioned.
Do you think it would be worth getting the tune double checked?
Ideally if your tuner could hit the track with you, you could log and see what it's doing. Those shift points might be low, plus if you log you will know for sure where it's shifting.
Converter lockup is useful to look at too.
I've seen folks with your mods go anywhere from 11.4 to 11.7 dialed in and with some weight reduction.
We did a lot of track tuning with my 2010 last Thursday and it made a big difference. Went higher on the shift points than I would have expected, but also a surprise, we keep raising the TC lockup RPM because that's what it wants. I would have thought opposite from what I've read.
I will talk to my tuner about looking at the tune and I would love to have him at the track with me , but don't think that will happen.
I may just have to finally buy HP tuners and start learning my self how to use it.
I am planing on hitting the track tomorrow and it seems I have my IAT issue worked out so hopefully it will do a little better. I will post my results.
I went to the track on Saturday and made 2 good passes. First was 12.02 and second was 11.98. The DA was between 1150 and 1200. I will upload the slips after work. I am close to where I was before the stall change, but my ET has not benefited from the stall change or the better 60 ft.
I talked with the tuner and he seems to think that my shift points should be fine and I am losing on the big end due to converter efficiency. He told me when he tuned the car that the stall was good and not to raise it.
I talked with Precision Industries and they said we that small increase in stall and at 3600 the efficiency should not be that different from when it was at 3200. And 3600 is not even that high of a stall compared to what some people run.
I doubt the stall is too high, I see people with higher stalls all the time that do not complain about efficiency. In fact when I was at the track there was a bolt on Camaro running a Yank 4000 stall, I forget which model and a bolt on GTO running a FTI 3600 stall.
Any thoughts would be great and I will load up those slips as soon as I get a chance.
You run a full tenth faster 60' than your previous best, but show no ET drop. Your MPH should stay the same as you didn't add power or take weight out and assuming the converter is just as efficient.
Our last passes have basically the same ET so I'm sure it can't hurt to compare slips to narrow down the issue:
60': I went 1.71 and you went 1.65(?)
1/8: 7.632 @ 90.37 (I'm not sure what you ran)
1/4: 11.979 @ 112.92 11.98 @ 114.5
It doesn't make sense that you left quicker by .06 but we ended the same with you trapping higher.
Imagine this: We have the same reaction time. You would pull ahead right away, but I would pull head probably shifting into second. By the end of the track, you have 1.5 mph on me and catch up to dead even.
Basically, something isn't as efficient as it should be between the start and finish. I really believe you should be shifting at at least 6500 with your cam and not your current 6200-6300 like you said. I'm shifting at 6200 with the stock cam. I believe you are shifting short of the ideal shift point for your cam and those couple hundred rpm aren't being carried from the 1-2 and 2-3 shifts through the run. I really think you have a few more mph in your setup.
How does your trans feel? Shift quick and hard? If it's slipping any, then I can see how you are getting mixed results. If it's good, then it's probably in your tune. Here's my last pass if you want to see how my rebuilt trans shifts with the Yank converter and Frost tune:
I emailed Geoff at EPS to ask his opinion and missed his call but will call him back tomorrow.
Also here are the two good passes time slips that I mentioned earlier.
