Wanting to get in 11's
What was the 60' on the 12.8 pass? Are you fixing a major traction issue? If so, then maybe yes. But the 109 mph trap seems to slow for 11's.
Don't feel like I'm singling you out here, but what's your end goal? I mean this is a pretty wild mish mash of parts, and I'm not surprised at all that it under performs. Here is my thinking
1. First thing that sticks out like a sore thumb is that cam. Who spec'd it with that god awful exhaust lift? If you want to make a lot of power, that's not the right cam. If you want to make a ton of noise, then don't change a thing, cause I bet it sounds choppy as hell.
2. Do you need to run the dual plane? Hot Rod/Motor Trend's David Freiburger just posted a newer video on youtube comparing dual plane/short ram/tall ram setups, and picked up 50 fwhp going to the tall ram/dual carb setup. Video is here if you're interested.
3. Heads. With a 4+ inch bore, why not LS3 style heads? They flow more out of the box than any stock LS1 style.
4. Headers. Again, why the compromise of 1 3/4 headers? Big motor's gotta breathe. 1 7/8 would help, but I bet 2 inch wouldn't hurt and would let you grow with the nitrous. What is the rest of the exhaust? Does it go into some janky *** y-pipe and then a 2 inch pipe to the bumper or is it true dual? We need some more info here.
5. Might it be under carb'd? Carbs really aren't my thing, but I understand CFM, and a stock LS1 78mm throttle body will flow over 700cfm. More airflow means more boom.. Speaking of which, what is the AFR? Is the carb jetted properly? That low MPH makes me think not, and probably not enough advance either.
That should be a good start on getting things figured out. I vote to spray the rods out of it asap.
60ft- 1.999
1/8- 8.38
1/8 mph - 86.6
Converter was a jw flashing around 2,800. Truck was lugging on launch
1. Martin Smallwood specd the cam.
2. I will be changing to Vic Jr single plane soon. I went with dual plane at the time as it was mostly street
3. As far as heads I was running low on $ at the time of the motor build and just stuck with them
4. Schoenfeld made a set of headers for ls swap in 88-98 model trucks so I used them. Only came in 1 3/4 primaries. Exhaust is a true dual 3" into spintech mufflers. I know these are probably choking it some
5. I have thought of changing the carb. Afr was low to mid 13s during the run so it was running a little lean I need to jet up. Timing is at 32*.
You need to figure the AFR out for sure. That's probably your MPH right there. Timing seems super high for pump gas. Have you pulled plugs to check the fuel ring and timing mark on the strap?
Do you know how much the truck weighs Baron? Just doing a little research it looks like most weigh 4000lbs. so it's not a featherweight by any means. That said it will need more stall speed and gear to get it moving.
2. Do you need to run the dual plane? Hot Rod/Motor Trend's David Freiburger just posted a newer video on youtube comparing dual plane/short ram/tall ram setups, and picked up 50 fwhp going to the tall ram/dual carb setup. Video is here if you're interested. Dyno Proven: 50 HP With One Bolt-On! - Engine Masters Ep. 1 - YouTube
The pressure differential between the cylinder on the power stroke and the exhaust port before the valve opens is so great that nearly 50% or more of the cylinder's contents are evacuated during blow down by the time the piston reaches BDC.
If the exhaust center line on the cam is 114* BTDC, then what good is adding more lift 66* ABDC going to help with if 50% or more of the exhaust gas is already gone 66 crank degrees before that? By that time during the exhaust stroke scavenging and pressure wave tuning will start to kick in and help pull the remaining spent gasses from the cylinder as the piston travels to TDC.
The only time you run even close to, the same amount, or more exhaust lift than intake lift is when you have to sacrifice exhaust valve diameter for intake valve diameter. Such as on a high RPM N/A engine where maximum bore diameter and maximum intake valve diameter is desired. To effectively center the intake valve the exhaust valve must be made smaller and shoved up against the cylinder wall. Thus more lift is needed to make up for the loss in curtain area.
The small amount of change from .578" lift to .600" lift would show no gain whatsoever on the dyno. Especially on a cathedral port head that has better intake to exhaust flow bias than other LS cylinder heads.
60ft- 1.999
1/8- 8.38
1/8 mph - 86.6
It may even cause traction issues from hitting the tire harder with more power which will present a whole different set of challenges. That said, with the adjustable shocks, cal tracs and big and littles I think you'll be just fine.
The change from heavier wheels and tires to the smaller skinnies up front and lighter wheels out back will also help drop the E.T. and gain MPH.
With all the changes you made you have a good recipe to get this truck into the 11.90 zone.
