Help with plumbing cooling system without radiator?
Not sure if this is the right section for it and i'm not signed up to YB yet so thought i'd ask here first!
I'll be running a 5 gall water tank in the rear of the car w/ -12 lines to and from the engine w/ a Rule 2000 pump.
Now my questions are is it ok to run the system un pressurized w/ a -12 vent off the top of the water tank?
What should i do with the steam vent lines?
One more thing is that the turbos i'm running only require water and no oil to be fed to the center section so where should i plumb those from?
Here's a pic of the water tank which will be higher than the engine itself which i hope will help.
Thanks!
High point vents are the most effective way to get air out of any cooling system. I would use the steam ports on the motor as the high point vent on the engine. Tie all the steam ports together and add a small valve that you can use to bleed the air out with, also i would tie the steamports into your main cooling system so that you will have flow through the steamports and any unbleed air can be pushed out of the motor and to your tank.
Also filling the system from the bottom up will help in pushing air out the top through your high point vents.
Anywhere your cooilng hoses go down then up then down again is a potiental area for air to be trapped. Take your time filling the system from the bottom up and bleeding it multiple times and you will get the air completely out.
Your tank will not need to be completely air tight. I would vent it out the rear of you car to allow for expansion.
Hope this helps.
Like I said if you give more info on what the intent is and more detail on set up n what not you might get more responses
If you're running Alcohol, consider dry decking and filling the block just cooling the heads, it would be much safer in the event you lift a head.
The steam vents can be plumbed Into 1 -4 line and ran back to the water tank. As for the turbo water supply, how much water is needed ?
Still trying to figure this out before getting started plumbing and i spoke to Comp Turbo regarding this and he said that water is def. needed and suggested to run -6 lines from the water tank in back.
I understand what he's saying but not really an option imo as it only has 2 (-12an) fitting for inlet/outlet so i'd have to "T" off of them for it to work and in that case i'd rather run a "T" up from the engine area near the turbos so not sure if anyone makes a -12an "T" with a -6an male fitting off the center of it and i'd need 2 of them.
I'll look around if not i'll have to have something fab'd up i guess
Hope this helps.
I'd feel more comfortable running the water tank set-up in case we race and have to go rounds and cool the engine down as needed.
I do have a steam vent kit already merging to 1 -4an line and was thinking of routing it to a little can/tank up higher than the engine instead of having to run a line all the way back to the tank does that sound feasible?
If anyone has an y leads on a "T" that can have -12's on either side with -6 in the middle please lmk or any other solution is appreciated!
http://www.jegs.com/i/Earls/361/9251...d=#moreDetails
With one of these coming off the "T" going to the turbos and then back?
http://www.jegs.com/i/Earls/361/9919...d=#moreDetails
This sounds like it's going to get very expensive quickly
