Drag Racing Tech
Threading or welding engine plate for remote water pump set up?
Old Feb 13, 2016 | 10:28 AM
Don Nguyen's Avatar
Default Threading or welding engine plate for remote water pump set up?
Trying to see if anyone has threaded or welded their front engine plates to accept remote water pump fittings directly.
Does anyone know if they sell some fittings/attachments that are designed to be welded on vs bolted on for a lower profile fitment?
Old Feb 15, 2016 | 08:48 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
I have a set of threaded adapter plated available that is exactly what you need. It is designed as a bolt-on as all the aftermarket ones are, but you probably could weld them to the plate if you really wanted. Cost is usually around 100 shipped.
Old Feb 15, 2016 | 11:15 AM
ATwelveSec02Z28's Avatar
I welded -12 male bungs onto my motor plate.... But had issues with cracking and have since gone to the meziere adapters.
Old Feb 15, 2016 | 11:16 AM
Don Nguyen's Avatar
That's interesting that you had cracking issues. I wonder what was the cause of the cracks.
Old Feb 15, 2016 | 02:35 PM
Cracks were because the -12 bung didn't fit well over rectangular hole in the motorplate. Then clearing everything to fit, getting it bolted into the car etc had some flex.
I re welded twice before I called it quits and got the adapter blocks
Old Feb 15, 2016 | 04:41 PM
Don Nguyen's Avatar
Good to know, thanks for the info. I was considering trying something similar, but will look at other options then.
