Drag Racing Tech
Anybody try MT Pro Bracket Radial ??
Old Mar 24, 2016 | 04:20 PM
LC2's Avatar
LC2
Default Anybody try MT Pro Bracket Radial ??
I like the idea of it
Old Mar 26, 2016 | 10:24 AM
Firebirdmuscle's Avatar
Yes 26x10.5 produces very consistent 60's and tire temp for me.
Old Mar 26, 2016 | 04:04 PM
LC2's Avatar
LC2
Thanks. What tire did you use before? Wondering if there's any mph loss from the et street radial
Old Mar 26, 2016 | 09:03 PM
It wasn't for me from switching from a hoosier dr
Old Mar 31, 2016 | 09:04 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
We run the 29.5x10.5x15.
Love these tires. 1.33 to 1.35 60fts, with 102 runs on them.
Old Mar 31, 2016 | 05:19 PM
LC2's Avatar
LC2
Thanks, I'm gonna go with them. What's your tire pressure with those 60's?
Old Mar 31, 2016 | 05:38 PM
Dimeomboost's Avatar
Probably ten of us run the same tire most love it actually everyone but me loves it I've seen from 14# to 20# pressures depends on what car I'm helping with but it's not the tires fault really my truck is just to light and the turbo comes on to strong 2.6 60' but they feel good once they hook for me
Old Apr 4, 2016 | 10:00 AM
18 psi
Old Apr 4, 2016 | 12:18 PM
BlackSS4thgen's Avatar
2 of the 3 guys have used the 28x10.5 brackets. Both of us switched from the et pro. 60's remain the same but seem to hook on less desirable surfaces also.
7-800whp street cars cutting 1.22-1.28 60's
my buddies fox is running 15 psi. my buddies fbody is 17/18 psi. I ran 15 in my fbody.
I like how the bracket does not seem to bead up and roll rubber off like the et pro. They will probably last longer. I cant really tell yet. I only have 20 miles on mine and 2 passes.
Old Apr 4, 2016 | 12:41 PM
WS6TransAm01's Avatar
CARTEK Racing
anyone hooking with these in a stick car?
Old Aug 16, 2016 | 03:01 PM
Bowtiedford's Avatar
are the tires feathering? my 28x9 Bias have a feathering look when their hooking good and about a mid 130 60'. I've lost 3 tenths on my 60 on these new 28x9 Pro bracket radial but only made a few passes and they still have a smooth finish. So maybe they need more time? I'm running 17 psi.
Old Aug 19, 2016 | 10:05 AM
Dark SS's Avatar
What's your set up and what 60's are you seeing? I'm wanting to give the 26" pro brackets a try.
Old Sep 19, 2016 | 03:07 PM
silent_assassin's Avatar
been plenty 1.teen 60' on 28x10.5 pro bracket and they last a long time
Old Sep 19, 2016 | 03:31 PM
Bolt ons, 4l80e and running a 9" with 3.70's. I'm shifting into OD a good bit before finish line and that's with my shift points at 6k. You might want to look at the 28" if your geared a little lower than me. I wish they made this tire in a 27"
It cuts very consistent 60' times. I am always around 1.54-1.57
Old Sep 20, 2016 | 10:39 AM
a05c's Avatar
Are they kicking the tires at 2.6 into the run or is it going 2.6 60' ?
Old Sep 24, 2016 | 05:17 PM
64post's Avatar
I'd like to know that as well, anybody?
