Drag Racing Tech
Ms4 with stock lifters
Old Apr 17, 2016 | 04:17 PM
RedSS24's Avatar
Default Ms4 with stock lifters
Installing a ms4 cam into my 2001 Camaro SS with 86k miles will I need to replace the stock lifters? Or will they be safe to use
Old Apr 18, 2016 | 12:19 AM
SteenH's Avatar
Don't replace them. Absolutely no reason to. Aslong as the rest of your valve-train is in check you're good to go.
Old Apr 20, 2016 | 12:06 AM
VandykeT/A's Avatar
it should be fine assuming everything is healthy
Old Apr 25, 2016 | 08:23 AM
Mean87SS's Avatar
Fine, if you are doing a 'cam only' setup and not pulling the heads.
