Help with a budget bracket race setup
Will be put in a 67 Firebird, stock eliminator suspension setup - Cal tracks, 12 bolt with 4:88's, 29x9 slicks, glide with 5000 stall, and adding a T brake. Car works pretty well, 1.48 60' times with IHRA ZZ4 combo currently.
Thinking stock bottom end, add cam/lifters/springs, headers, electric water pump, MSD box. Will be intake with Alky carb setup.
Anyone running a combo like this? What motor - heads do I want? What cam suggestions? What RPM can I run with stock bottom end?
Remember, budget and new to LS motors... more details the better!
thanks in advance
Ken
1/2 fill the 6.0 block, studs in the bottom end and I would pin the caps for the sake of doing it. Alcohol you won't need a lot of cooling so small radiator, and the lower flowing mez. Pump would be fine, won't need a tstat.
If there is anything we can do for you please feel free to give us a call or shoot us a email.
We definitely can get you going with something cost friendly.
Thank you,
Thompson Motorsports
972-853-2450
dustin@thompsonmotorsports.net
