Weight reduction list for the daily driver...
What do you think you gained by removing the rear swaybar?
Here's what I would do.
1) If you have cd-changer ditch it.
2) Dynabatt battery
3) High flow lightweight cats
4) Light weight catback installed where it can easily be removed at the track (30-50 lb weight reduction!)
5) Light weight carpet...use stock sound deadener.
6) Light weight fiberglass hood (using stock fasteners...note not talking suncoast/ascd etc..those ARE HEAVY!)
7) Aftermarket mild steel k-member/arms
8) light wheels
9) get use to removing sway-bar prior to track ( easy after you do it a time or two )
10) Light weight seats
Things I would avoid:
1) removal of air/egr/cats especially if you have to get sniffed for inspection.
2) removal of sound deadener in daily driver or use of short exhaust ( dumping under passenger compartment )
3) absolutely wouldn't pull bumper supports /doorbars in a daily driver.
<small>[ April 12, 2002, 12:27 PM: Message edited by: PaiN ]</small>
