Front torque arm adjustment
Rear is lower control arms at 1.5 degrees down compared to the chassis, bmr xtreme anti rollbar, cut stock springs, viking shocks at c=15, r=5, -2 degrees pinion angle, long BMR torque arm as low as the front will go.
275/60/15 Pro, 20 psi, leaving on 250, 3.70 rear gear.
What lead you to those shock settings? Viking and BMR told me to go the opposite way and set the rebound high and compression low. I tried the torque arm as low as I can get it, LCA in middle hole and it still won't hook. I didn't have anyone to video this time so I was trying to adjust the shocks from what I could feel. I ended up at 8 and 8 but it still wouldn't hold if I sprayed out of the hole.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Rob
I've heard a couple times that someone thinks it's a suspension problem but it turned out the tires were junk. Just a thought. Do you have another set of tires to try?
