Drag Racing Tech
Serious HP question---->
Old Apr 22, 2002 | 09:45 AM
JS's Avatar
JS
Default Serious HP question---->
Okay sy u have 380RWHP and r running 11.40's at 117.Then u add 60RWHP to the car.
What would u expect to pick up in ET and MPH
The reason I ask is I believe at 11.40's u will not see the gains u would if say u were running 12.00 and added 60RWHP.Diminish and return come into play and its takes more hp to gain a tenth as a car gets quicker and quicker.
I've been told 3 tenths and 3 mph would be realistic but I feel more like 4 tenths and 4 MPH would be on par?
I want real opinions not somebody flaming me.
Chris B.,Pain,PSJ,Nineball type response's please...
JS
Old Apr 22, 2002 | 09:56 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Serious HP question---->
Once you get into the 11s, the simple "10hp=tenth" approximation doesn't apply.
I'd estimate just under 4 tenths and 4 mph for the ET/MPH range you are considering.
For example, I went from 11.61 @ 400 rwhp to 11.21 at 455 rwhp with no other changes. 60' times were a little better on the 11.21 setup also, about a half a tenth.
Tony
Old Apr 22, 2002 | 09:58 AM
CHRISPY's Avatar
Ditto what Nineball said about 4 tenths and 3.5-4mph tops given that traction is the same. Also depends on where you gain the power. If you pick up 60RWHP in the 4000-5500 range you will pick up more than if you gain 60RWHP in the 5700-7500rpm range. This is dependant on vehicle weight and gearing of course <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Cheers,
Chris
<small>[ April 22, 2002, 10:03 AM: Message edited by: Chris ARE 360 ]</small>
Old Apr 22, 2002 | 10:12 AM
Fireball's Avatar
also I don't put any faith in peak power gains, to me it don't mean crap...its how much hp you put down the whole 1/4 mile (area under the curve)
Old Apr 22, 2002 | 10:21 AM
Terry Burger's Avatar
You just look at the average power between your shift extension (in my car 5700rpm) and redline. The dynojet software will do it for you.
Old Apr 22, 2002 | 10:29 AM
JS's Avatar
JS
That makes me real happy.I figured it was max 4 tenths and 4 mph.
Well the best I ran in -1781 DA's was 11.43@117 after 100 passes.The best this new sertup has gone with me driving is 11.29@119 but thats was in -110 DA's and only 5 runs since install too.
I'm hoping for 11 teens now and poss. another tenth towards the fall.Thanks guys...
JS
Old Apr 22, 2002 | 10:37 AM
Crazyquik's Avatar
At that speed level, you're looking closer to 15rwhp = ~tenth than 10 hp = tenth.
J.
