Drag Racing Tech
Need more traction
Old Nov 15, 2016 | 09:30 PM
chrisdiaz288's Avatar
Default Need more traction
What up ls1tech..
I have a 99 camaro it's a stock ls1 m6, I do have LT headers off road y and it's tuned. I'm looking for more traction. I have 19x10.5 rear wheels with 285/35 eagle f1 tires made by Goodyear. I have almost NO traction in first and second gear at WOT. Nitto sells 305/35 tires that seem like they would work well. I'm looking for better traction on the street. Should I get smaller wheels like 17's? Will the smaller wheel help with traction?? What are you guys all running on the street?
I lost a race because I couldn't get any traction in second gear
Old Nov 16, 2016 | 01:23 AM
NewOrleansLT1's Avatar
You need drag radials.. Look into Nitto or Mickey Thompson drag radials for daily driver use..
Old Nov 16, 2016 | 08:30 AM
Since I have 19 inch wheels I can only fit a short sidewall will that affect my traction with a drag radial? Should I buy smaller wheels first?
Old Nov 16, 2016 | 08:56 AM
Aaron at SDPC's Avatar
If you are looking to make a big improvement on traction a smaller set of wheels with a drag radial is a much better way to go. With the 19" wheel your options are very limited and you have very little sidewall.
Old Nov 16, 2016 | 03:38 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
What up ls1tech..
Those Eagle F1's are a joke when it comes to traction. I had a set on my old Ws6 and they felt like they may as well have been made by Lego. I swapped to 17's with a set of Nitto NT05's and it was a world of difference. Going to a 15" with a drag radial will make an even more dramatic difference.
There are suspension factors that can contribute to this as well. Is your car lowered? Whether it is lowered or not, the addition of LCA relocation brackets will help the tires dig in and hook. Additionally, replacing the stock weak lower control arms with tubular ones will improve how the car plants. These are normally the first 2 steps I recommend to someone fighting traction issues
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Nov 17, 2016 | 11:23 AM
MidwestChassis's Avatar
There are many ways you can go with your car such as a more race-oriented tire and wheel combo, aftermarket shocks would also help also I would look into rear lca's, relocation brackets, and a torque arm these are only some of the items that can get you going on the right track.
