Drag Racing Tech
Line Lock Install - Brake Bleeding Question?
Old Apr 25, 2002 | 10:23 AM
Sparky's Avatar
Default Line Lock Install - Brake Bleeding Question?
Any advice on bleeding the system? Do I just do it the old fashioned way and start with the rt rear wheel - left rear - rt front and then the left front?? Should I also bleed anywhere else in the system first??
Thanks!
Mark
<small>[ April 25, 2002, 11:39 AM: Message edited by: Sparky ]</small>
Old Apr 25, 2002 | 03:52 PM
bigSS's Avatar
Default Re: Line Lock Install - Brake Bleeding Question?
For mine, I bled the passenger front first, drivers front second. Worked good for me!
Old Apr 26, 2002 | 12:47 AM
2000 Camaro SS's Avatar
You should only have interrupted the front brakes. If that is all that you did you only need to bleed the front brakes. The front and the rear are on two separate systems if I am correct.
Old Apr 26, 2002 | 12:54 AM
Sparky's Avatar
Thats what I was hoping! So, hook it up and bleed the right and then left fronts?!
Thanks!
Mark
