Drag Racing Tech
Optimum shift points for an A4?
Old Jun 23, 2004 | 10:32 PM
MNR-0's Avatar
Default Optimum shift points for an A4?
What are the optimum shift points for an unopened A4 with stock converter? Does it make any difference if the 2-3 shift is 5800 vs. 5900rpm?
Should you always shift at peak power or roll off a little, and by how much?
Say the dyno shows peak power hold on to within +-2rwkw from 5600rpm till redline 6200. Should you shift right on the red-line?
