2 step easy to install ?
I mounted the box on the driver side in front of the shock mount under the hood.
The directions make it really clear.
I have an auto and don't use a trans brake, so I used a reed switch on the brake pedal as well as a simple switch to active the brake pedal switch. If you wanted to you use it like that you could also get a pressure switch that gets fed brake pressure and switches at a certain PSI.
If you have more questions I can go over it all when I get home and get you some pictures.
