Drag Racing Tech
Hate to ask this question, but got to!
Old Jun 27, 2004 | 07:44 AM
C5Blake's Avatar
Default Hate to ask this question, but got to!
Hey yall, new to racing and need to know how to launch and shift. I hope yall don't tormen me too much, but I gotta get it right, I'd hate to get walked on cause I drivin her wrong. Thanks a lot for the help.
Thanks,
Blake
Old Jun 27, 2004 | 08:28 AM
racer88's Avatar
I'd have to tell you to get a shift light and set it to 5800-6K. Shift on the light, and do it fast. Depends on how fast you shift you don't wanna hit the rev limiter that costs you time. The stock tachs pretty much suck so getting a shift light is a good start. Just be careful not to mis-shift!
As for your launch, you just gotta practice and find where your car can launch. On street tires I'd have to say drop the air to about 22-24 and just go out around 2K or 2500 if you can slip the clutch til you feel movement then let it rip. Depends on how good the track is you are going to. The stickier it is the better and better chance you will get a good launch to go out at 2500.
You just gotta go there.....hard to explain but that's what I would do. The harder the track hooks the higher I launch with mine. I am on drag radials tho....you might want to pick up those too before you go.
Try it is all you can do.
Old Jun 27, 2004 | 08:48 AM
CHRISPY's Avatar
If you are running ET streets or ET drags here are some instructions on how to burnout and launch. (You can use these instructions to burnout for drag radials too)
1) gently spin the tires in the waterbox and move forward about 3-4 feet to an area that is just damp.
Do your burnout in second gear, bring the revs to 6000rpm and hold it till the tires start to bite
2) let off the brake/linelock but still let the tires spin as you roll forward. You'll feel them suddenly bite. Then you know you are ready
3) Stage and bring up the revs (depending on how the track is behaving this could be 3500rpm to 7000rpm)
4) On the third yellow floor the gas and lift straight up on the clutch at the same time as fast as you can.
Be sure to floor it as you lift the clutch straight up or you'll bog and then spin as the chassis loads/unloads. Also dont sidestep the clutch, unnecessary shock on the drivetrain and tires
Old Jun 27, 2004 | 08:54 AM
racer88's Avatar
I do my burnouts in 1st gear all the time. I can't see doing this to a stock rear end
Oh yeah and burnouts to me are the most fun.
Old Jun 27, 2004 | 08:57 AM
CHRISPY's Avatar
Burnouts are EASY in second gear with a stock rear. You wont get enough tire speed to really heat the tires in first gear
Old Jun 27, 2004 | 09:15 AM
racer88's Avatar
I dunno, I did them in 1st w/ my 10 bolt too and cut 1.74 shorts on it w/ drag radials pretty much the same w/ my 12 bolt.
I guess whatever works for you stick w/ it
Old Jun 27, 2004 | 09:24 AM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
I do 1st gear burnouts in the Z.Best 60 ft is in sig.When I get the linelock on I plan on grabbing 2nd in the burnout box.
Old Jun 27, 2004 | 09:32 AM
C5Blake's Avatar
Thanks a lot guys, if it ever stops raining in Alabama I'll get out here and practice. One more when you shift should you let all the way out on the gas or stay in it? Sorry for all these "dumb" questions, but I just don't know.
Thanks again,
Blake
Old Jun 27, 2004 | 10:46 AM
racer88's Avatar
I don't know....all I know is I shift fast! Now you gotta confuse me.
Old Jun 27, 2004 | 11:06 AM
SMOKIN01TA's Avatar
ditto,
i dont entirely let off the gas, if i had a built bottom end i'd hold it pinned to the floor
Old Jun 27, 2004 | 12:13 PM
McRat's Avatar
The problem with second gear burnouts is it will accelerate your clutch wear, and increase the chance of your clutch sticking to the floor.
