Drag Racing Tech
Launching a Manual
Old May 26, 2017 | 12:58 PM
gesto's Avatar
Originally Posted by nmass399
The best setups have an adjustable clutch or a clutch slipper device like I have.
Guessing you have a clutch tamer? How do you keep it from slipping 2nd, 3rd and 4th, i.e., so it only slips on launch?
Old May 26, 2017 | 08:11 PM
KingPin1094's Avatar
Originally Posted by blk00ss
With it dead hooking like that on those radials, your slip yoke won't last long. I would actually already bet it's twisted some. You need some bias plys. If you don't plan on making anymore power for a little while, I would run some stiffwall 26" slicks. You need all the help you can get. Your cars down on power a good bit it seems.
The yoke on the driveshaft is fine, its a PST 3.5" driveshaft, however the output shaft splines may be twisted.
Yea i accidentally built the car with a stock fuel pump, so it leaned out a ton. I have since changed the pump but have not gotten it re-tuned to see if i can pick up more power.
Old May 26, 2017 | 08:31 PM
blk00ss's Avatar
Lol. If you think the splines on the output shaft will twist before the slip yoke, you got another thing coming. Unless you got the good chromoly strange or mark Williams yoke, it will happen. You don't have to believe me but I've seen it numerous times on my car. I had a strange 3" chromoly DS with their basic slip yoke. Twisted splines just by leaving hard on the street.
Old May 26, 2017 | 10:41 PM
nmass399's Avatar
I'm letting it slip in all gears at the moment. I've been brain storming some about what I could do about that. I want to have something disengage it very quickly with hardly any effort. I'll figure something out eventually.
Old May 27, 2017 | 10:09 AM
64post's Avatar
One other way to launch your t56 is to use a McLeod soft-lock clutch or other brands clutch like the Soft-lock, it allows up to one revolution of slip on launch avoiding the drive line "SHOCK", these style of slip clutches are used in many stock eliminator stick classes.
