Drag Racing Tech
Front sway bar
Old May 20, 2017 | 09:45 AM
deerslayinrednek's Avatar
Default Front sway bar
I currently have a car running mid 12's and hooking. The front sway bar is still on it, would I gain anything from unhooking it?
Old May 20, 2017 | 11:43 AM
01ssreda4's Avatar
Will transfer weight better and faster.
Old May 21, 2017 | 09:27 PM
gesto's Avatar
a little weight savings if you remove it.
Old May 25, 2017 | 03:24 PM
93camaro_zzz's Avatar
It absolutely will help. Take it off.
Old May 25, 2017 | 06:29 PM
01ssreda4's Avatar
a lot, about 30 pounds with brackets and hardware.
Old May 26, 2017 | 01:42 PM
I guess my question is if I unhook it but leave it on and tighten up the rear shocks will it pick up time in the 60'? The car has no issues with traction but 60's are mid 1.7's
I'm doing some other things first, I don't want to change everything at once so I can see what helps.
Tonights menu is trying the skinnys on the front and the chrs1313 ram air.
Old May 26, 2017 | 04:49 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Just unhooking it but not removing it will have minimal effects. It may help a little, but don't expect any miracles from it
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old May 26, 2017 | 05:24 PM
Jtm2085's Avatar
Just remove it. I promise you won't miss it
Old May 26, 2017 | 05:42 PM
01ssreda4's Avatar
I agree, except i dont think it will help at all. The point of removing it is to make the car hook more consistently. If you're hooking now thats fine, but removed it will help when situations are less then optimal or you are making more power.
