Drag Racing Tech
Paging Pro Stock John
Old May 18, 2002 | 10:03 AM
kent's Avatar
Default Paging Pro Stock John
Heeded your advice on settings on the rear of my A4 99SS concerning Hal shocks. Set D Rear at 6 and P Rear at 9. I have never stiffened the rear as tight before with the rear. This is a totally new approach for me, but I willing to try new things for a better 60'time. As suppose the front end of your car is light such as K Member, upper and lower control arms, skinnies, etc. If it doesn't rain today, I will be running skinnies and slicks at the same time. I am hoping the skinnies up front will lighten front of the car for a better weight transfer. Temperature down here is in the 60 to 68 range and looks very promising. Any more advice from you and anyone will be sincerely appreciated.
Old May 18, 2002 | 01:33 PM
Colonel's Avatar
Default Re: Paging Pro Stock John
"Set D Rear at 6 and P Rear at 9."
Hope your track is hooking well. If it's not you'll want to try them a little looser. Like maybe 3 on the left and 4 on the right...maybe even 2 and 3.
<small>[ May 18, 2002, 01:34 PM: Message edited by: Colonel ]</small>
Old May 18, 2002 | 09:16 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Keep in mind that stockers are 50/50 so that is like 6 or 7. 3-4 (loose) is for less than desirable track conditions but there is always time to experiment.
