Vacuum lines and catch can advice
The car doesn't have any HVAC so that isn't a concern. I have the line for the brake booster hooked up to a fitting on the intake and the map sensor hooked up to a different fitting on the intake. What I have left is the driver's side valve cover (I guess that was a factory PCV location) and the two fittings on the passenger side valve cover.
My question is, where should I be hooking these up to and do I need a catch can at all? The catch can has a PVC in it...
Last step connect a 3/8 inch hose from the front port of the passenger valve cover to the port on your throttle body and your done!
