Drag Racing Tech
Line Lock Question
Old May 28, 2002 | 11:19 AM
ShadowZ28's Avatar
Default Line Lock Question
I have a Moroso Line Lock that looks exactly like the SLP one. Anyway I need to know the size of the brake lines cause I gotta go to Pepboys and pick up them and bend them myself since the Line Lock only came with the solenoid, switch, light and fuse. Does anyone know the size of the lines and am I missing anything I'll need to install it? I also need to know the size of the fittings that screw into the the Master Cylinder and ABS block if anyone knows.
Thanks
Joe
Old May 30, 2002 | 02:20 PM
Lar's SS's Avatar
Default Re: Line Lock Question
You may run into a problem. I don't know the size, but I think the reason the pre-bent lines are so easy is because they have the proper metric and standard fittings on them already. The car is metric and the lock housing is standard. I guess you could cut a flare your own, then bend those.
Do-able, just a PITA.
