Drag Racing Tech
Taking the Stripe
Old Oct 10, 2017 | 08:44 PM
deerslayinrednek's Avatar
Default Taking the Stripe
Do our cars hit the finish line beam with the nose,air dam, or the tires? The air dam on mine sits at 4-5" from the ground but I'm not sure how high it is under power.
Old Oct 10, 2017 | 08:46 PM
NHRAFORMULA00's Avatar
the finish line beams are 9-10 inches above the surface on nhra tracks.
Old Oct 11, 2017 | 04:08 AM
nj02z's Avatar
Search "Stripe Taker". I run one. It must be 3.5 off the ground.It can be a sly little trick, dumping the nose in the beams when someone is watching your tires.
Old Oct 11, 2017 | 08:05 AM
Unfortunately I don't have the experience you have to be trying tricks.
I always seem to be taking too much stripe.
Old Oct 11, 2017 | 08:17 AM
nj02z's Avatar
It could give you a more consistent way of tripping the beams.If you are on the brakes trying not to take to much you might be dipping the front of the car.
Old Oct 11, 2017 | 08:43 AM
Does yours attach under the bumper or to the front of the air dam?
Old Oct 11, 2017 | 10:08 AM
nj02z's Avatar
Attaches to both spots.
Old Oct 11, 2017 | 11:14 AM
conexion914's Avatar
Have any pictures?
 Michael S. Palmer
Old Oct 14, 2017 | 09:32 PM
HotRod H269's Avatar
My first time bracket racing my 02 camaro resulting in quite a few breakouts from getting on the brakes and tripping the beams with the front air deflector on the radiator support. I took it off and made a stripe taker and mounted it under the front bumper cover. Seemed to help if you know how to use it to your advantage!
Old Oct 16, 2017 | 05:16 PM
nj02z's Avatar
