Drag Racing Tech
moving axle backwards
Old Oct 13, 2017 | 05:01 AM
fastlt1's Avatar
Default moving axle backwards
I'll probably have to get new driveline made with the new nine inch. I remember reading about moving the axle back a inch to clear bigger tires but you have to have a new driveline made. Do you just measure stock lca and adjust the adjustable ones a inch longer. Any thing else. Thanks
Old Oct 13, 2017 | 10:06 AM
01ssreda4's Avatar
Mine were too far back and needed to come forward. Best thing to do is just mount a set and see where you're at.
Old Oct 13, 2017 | 07:03 PM
jhshnh's Avatar
1" may be too far. When I put my S60 in it was over an inch further back than stock wheelbase and my 26" tires wouldn't fit.
I have adjustable lcas (and everything else) so I put my wheelbase back to stock which is 101.1 inches. It wasn't that hard with simple measuring tools and pulling off the front wheels for exact measurements.
Old Oct 13, 2017 | 07:09 PM
jhshnh's Avatar
Sorry for 2 responses but to answer your question about setting your lcas one inch longer the answer is probably not. Your nine inch probably has different slots for your lcas which put the lcas at a different angle than stock... if you have it setup like that (which I do to get the desired negative angle I wanted).
I've only ran 26" tires but I highly recommend getting your wheelbase, pinion angle, lcas angles, and panhard adjustments exactly right with your desired ride height and use of the car.
Old Oct 14, 2017 | 11:57 AM
Darth_V8r's Avatar
Moderator
Probably the least technical answer possible, but I just eyeballed it on the passenger side, measured the diagonals and adjusted the driver side to match. Center of the well worked for 28’s for me
Old Oct 16, 2017 | 10:03 AM
AnotherWs6's Avatar
^^^^Lol, mine are just basically eyeballed as well. Just kept taking wheel to quarter measurements at the same spot on both sides until I felt they were both as close to perfect as me and a tape measure were gonna get them. Car doesn't pull dog walk so I think they are fine.
Old Oct 16, 2017 | 10:54 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
I normally recommend to install an adjustable LCA by setting it to the same length as a stock arm first, then adjusting it once it is installed on the car. I normally like to reference the stock wheelbase of 101.1". Make sure your rear is close to this. But if for some reason you have to vary from that measurement, the most important thing is that it is even side to side. So whatever you do set the wheelbase to, make sure both side match so you don't end up with thrust angle problems
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Oct 16, 2017 | 12:33 PM
nmass399's Avatar
+1 this is pretty much what I did with the lca's and the panhand bar. Gets everything pretty close then go from there.
