Drag Racing Tech
ls malibu
Old Dec 17, 2017 | 01:35 PM
gbodyhustle's Avatar
Default ls malibu
new to the forum and was hoping you guys would give your experianced opinion. ive started an 80 malibu build for the 1/8th. as usual was gna stay simple and on a budgett lol. now i have a quick perf 9inch on 456 spool. 400 turbo on a trans brake 3800 stall. truck 5.3 lq4 that ive gone threw bottom end and polished with kings bearings arp rodbolts 4.8 flattops btr stage4 cam port polish big valves. springs and pushrods to match cam. super vic and planin on a hollet ultra dp. 750-850 undecided with a nx 150 plate system. obviously tha budget went out the window. in the begining i was looking to run low 7sin the 1/8th and set up a safe car with a good cage a d suspension. any idea what kinda times this setup should turn in the 1/8th??? may make a difference in the way i finish the car. anybody with a simalar setup info will be greatley apreciated !
Old Dec 17, 2017 | 01:48 PM
Default ls malibu
meant to add my rear setup was a minitubb with moroso tricks on comp eng 50/50 adj uppers and boxed lowers. stock spring front on come eng 90/10s. gna stuff tha biggest slick i can fit and skiny front runers. any advice from experiance ?
