How to: Wolfe Door Panel Install
Realized right off the bat, the hole they cut for the door handle was a courtesy cut, and nowhere near correct for install.
This was my initial thinking, but ended up about doubling it due to me wanting the lock lever to be exposed.
The original mounts for the stock door panel (armrest screws) need to go bye bye. Also, notice how the lock lever kinda looks like a limp noodle when not supported by anything?
The plan is to use dsus or 1/4 turn fasteners, I want to be able to easily remove the panel if needed. Here's how they go together, the gold spring goes inside the door, riveted, and the black fastener is what you see on the outside of the door panel.
Here's one installed:
There are lots of things around the perimeter of the door that will obstruct placing your springs inside. I went around the door and marked Xs anywhere there was something in the way. Along the bottom of the door there is ribbing/reinforcement every few inches.
Here's where i selected the 5 could go with the least amount of issue, there is one more at the front corner that got cut out of the pic.
Here is my final passenger door cut for the handle and the lock lever:
Up close of the carbon fiber wrap I selected. Chinesium brand.
Lay out your wrap of choice. Once it was on i hit it very quickly with a heat gun on the low setting.
Driver door mock up, no trim, and need to put the switches somewhere, may extend them to the center console.
Add a little black paint around the handle:
Passenger door with trim installed. The rubber at the upper front of the door requires minor trimming, the rubber at the rear of the door does not.
Pic looking from the inside...notice how when i shut the door the lock lever popped out a tad?
I used the cutoff wheel to cut off the mounts, the bodysaw to trim the handle holes, the carbide grinder to finish them out, the file to take the ridges off my cuts, and the silver tar tape (roof repair) on the rear of the panel to give it a little weight so it wont rattle against the door, this step optional.
Couple of observations. I chose to delete my power mirror wiring. The part that plugs in has to go through the metal panel, where it used to slip behind the stocker. You'll need to drill a hole in the panel to allow it to pass through if you choose to keep it. If you want to extend the full driver switch panel its something like 19 wires., about half being lock/windows, and other half being mirrors. Other then that the panels fit nice and tight, but due to sheer size they are probably gonna resonate and rattle some. Probably be advisable to put something between them and the fiberglass door. I also put a zip tie loosely around the lock rod near the handle cause it flops around some. Putting a tie on it keeps it held up and supported.
Also, adding a puller strap would be nice to when wanting to shut the door.
How much weight do you think you saved doing this over the stock door panel?
OR just replace/redo all the switches with smaller ones. They are only simple toggle switches.
Hmmmm now I have some new ideas festering...
Just looked them up online...I see a $280 price tag...please tell me that is for both doors??
If you dont wanna cut/splice/extend, the stock harness will reach your new location. The issue is there are about 25 wires in the door, and about 5 need to stay. So you'll need to separate what goes to the switch, delete what you dont want, then pull it back through the boot. The long strand i have hung on the door is the plug in for the switch, separated and wrapped in tape and just propped up for the pic. The small strand coming out of the kickpanel next to it is power mirror and switch light wiring thats been cut and not needed.
Here's final install. Panel has probably been in storage for a year so its a little dusty but you get the idea. Works great and i can almost reach it when i pretend I'm strapped into a 5 point harness.
I'm looking at trimming inside the door too for extra savings. Did you do any of this?
my stock panels are cracked so thats why swapping them out.
