Drag Racing Tech
Car wiring question
Old Feb 8, 2018 | 12:15 AM
OxTheGreat's Avatar
Default Car wiring question
Racecar is running MS3 gold box, which controls just about everything.
Its Gen 3 LS based engine which has a complete harness and will require accessories wired up for boost controller, trans brake and oil temp. Separately, I plan on wiring up two relays and switches for dual fuel pumps, relays and switches for trans cooler, radiator fan and oil cooler, then the accessory and Start switches.
just as a sanity check, what else am I missing?
Old Feb 8, 2018 | 05:57 AM
B52bombardier1's Avatar
Alternator??? Jusy sayin' External car lighting perhaps required by your sanctioning body - brake lights?? Fuel tank sending unit?
I could probably think of a few more . . . ???
Rick
Old Feb 8, 2018 | 06:07 AM
OxTheGreat's Avatar
Rick
alternator is single wire unit, easy install
no exterior lights (yet). When I do, they will all be on their own systems using LEDs and aircraft grade 24ga wire
no fuel cell sending unit
