Drag Racing Tech
Gear ratio with TH400?
Old Mar 13, 2018 | 07:47 AM
LD_4X78's Avatar
Default Gear ratio with TH400?
What rear gear ratio are you guys running with a th400 transmission? I'm running mostly 1/8 mile. Rarely do I run 1/4. Thanks
Old Mar 13, 2018 | 07:57 AM
98CayenneT/A's Avatar
Here is a good gear calculator.
http://fitbodyshop.net/gear/index.php
Old Mar 15, 2018 | 06:27 AM
conexion914's Avatar
I run 4.10 with a 28x9 Pro Bracket Radial.
Do you drive the car on the street at all?
Old Mar 15, 2018 | 06:30 AM
LD_4X78's Avatar
Not very far. I'm thinking about going with a 4.56
Old Mar 15, 2018 | 09:25 AM
You should be able to use a gear calculator to see what your RPMs will look like without converter slip.
Standard TH400 gear ratios are 2.48, 1.48, 1
You'll just need to know what tire size.
