Drag Racing Tech
Power/weight ratios?
Old Jul 10, 2004 | 06:47 PM
tigris's Avatar
Default Power/weight ratios?
Assuming you have enough traction/suspension setup, What power/weight ratio will get you into 10's or 9's? Would 5 lbs to 1 hp be enough run solid nines? Thanks
Old Jul 12, 2004 | 03:59 PM
tigris's Avatar
Any help on this? Thanks
Old Jul 13, 2004 | 12:38 PM
Colonel's Avatar
My power (HP, not RWHP) to weight ratio when running 9.8s was ~4.85:1.
Old Jul 13, 2004 | 10:36 PM
Red01Chevy's Avatar
i think it would depend on your setup. i mean it would take more hp for a m6 then a A3 or A4 (if a A4 could handle it)gear is also a factor
Old Jul 19, 2004 | 06:29 PM
v8-7's Avatar
Colonel,,, how did you come up with those numbers.
Flywheel HP to the wieght of your car with driver or without?
-or-
Rwhp to the weight of your car with or without driver?
--did you use torque for any figures?
Curious to know becuase my car is 2800 without driver, 2950 with, and 570rwhp, so maybe 630 flywheel hp? Whats the % of loss from flywheel to the rears? i know it can depend on the dyno,, but whats the average% loss?
Using flywheel hp and wieght without driver my ratio is 4.44lbs to 1 hp
That sound correct? If so,,,
Old Jul 19, 2004 | 07:33 PM
Colonel's Avatar
As I said, "HP, not RWHP".
The weight I used was the actual raceweight (that means, with driver, helmet, laptop, gas, change in the center console, dirt, etc....)
The drivetrain loss (which actually IS NOT a fixed percentage) is *generally* about 83-88% (again, if you want to *call* it a percentage) with an auto and about 80-85% with a manual.
If we have 570 RWHP and assume 88% then that gives you 648 HP at the crank. 2950 lb/648 HP= 4.55:1
Old Jul 19, 2004 | 10:40 PM
rhamm1320's Avatar
I dont think its directly proportional (spelling?). A 50 hp increase in a grocery getter will make a huge difference, but a 50 hp increase in a pro stock will not change the et near as much.
Here is the easy way to play around with the numbers without all the math - plus its free.
http://www.virtualengine2000.com/ProgramDownload.htm
