Drag Racing Tech
Arctic White SS Build
Old Dec 31, 2019 | 07:30 AM
Innovate's Avatar
Awesome, how do you like the Jeg's wheels? I am thinking of grabbing the Spike's.
Old Dec 31, 2019 | 09:02 AM
mrbigjeep's Avatar
is there grinding required for the jegs/summit 15” rear wheels?
Old Dec 31, 2019 | 09:04 AM
AnnivSS's Avatar
They look and fit great. Other than that Ive never driven on them so I cant provide much more of a review than that. I traded the deep dish zr1 reps for the Jegs wheels. I have a pair of C6 front wheels that are going to be my street wheels for the front for now. They'll be powder coated to match the Jegs as close as possible.
Old Dec 31, 2019 | 10:03 AM
AnnivSS's Avatar
Slight grinding of the cooling fins on the rear calipers yeah. Or run LT brakes.
Old Jan 1, 2020 | 11:02 AM
mrbigjeep's Avatar
Good to know, thanks
Old Jan 13, 2020 | 10:49 AM
mrbigjeep's Avatar
What size tire and wheel combo is that In the rear?
and backspacing?
Old Jan 13, 2020 | 01:59 PM
AnnivSS's Avatar
The wheels are 15x8. Ill have to get the rest of the specs when I get home. Traded my ZR1 reps for them so I never saw the spec sheet.
Old Mar 20, 2020 | 09:32 AM
HATEDBIRD's Avatar
whats the backspace on the jegs rear rims?Also is your rear 15x8 or 10?Thinking about grabbing the exact ones you have.They look good on that thing!
Old Mar 20, 2020 | 10:13 AM
AnnivSS's Avatar
15x8, im not sure on the backspacing. I got them used off another fbody. I can check tonight im pulling them off to start rebuilding the rear brakes and swap the 93-97 calipers on.
Old Mar 20, 2020 | 10:50 AM
HATEDBIRD's Avatar
6.5 is the most they offer per JEGS.Id guess thats what you have but if you dont mind checking that would awesome
Old Mar 20, 2020 | 11:14 AM
AnnivSS's Avatar
Yeah no problem, I assume its cast into the back of the wheel.
Old Mar 20, 2020 | 02:58 PM
  #32
HATEDBIRD's Avatar
Should be,you might charge if you have to measure.lol
Old Mar 20, 2020 | 08:00 PM
  #33
ironmanLS1's Avatar
Got the front clip removed this weekend and started cleaning and repainting the engine bay. I cant stand a white engine bay so I shot mine with a satin hot rod black. Next order of business is to repair some rookie wiring splices on the harness correctly, and tuck the harness. I really want to pull the k member and torque arm and have them powder coated a different color but I may wait till the drivetrain comes back out for the built engine to go in. Its getting a junkyard motor for right now just to move under its own power.
What paint was that, spray bomb or something in a paint gun? Looks great btw. I am back and forth what to paint mine with on a pewter car. I could go urethane to match but I'm really thinking of copying your color!
Old Mar 21, 2020 | 11:00 AM
  #34
AnnivSS's Avatar
It's rusteoleum hot rod black primer of some sort. Ill take a pic of the can. I bought some satin black to spray over it but honestly the primer looks so good and is holding so well I may not even bother. Undecided yet.
Old Mar 21, 2020 | 12:41 PM
  #35
ironmanLS1's Avatar
Thanks, if you could post a picture I'd appreciate it. On Rusteoleum site I only found basic black primer.
Old Mar 21, 2020 | 12:44 PM
  #36
AnnivSS's Avatar
I stand corrected, its this stuff.
Amazon Amazon
Old Mar 21, 2020 | 09:10 PM
  #37
ironmanLS1's Avatar
Thanks, I'll check it out.
Old Apr 11, 2020 | 01:31 PM
  #38
AnnivSS's Avatar
Cut hours at work due to the pandemic have ground toy car business to an abrupt halt. Next order of business will be getting the 10 bolt pulled to be replaced with a 3.90 geared 31 spline 8.8.
Old Sep 5, 2020 | 02:33 PM
  #39
AnnivSS's Avatar
Not much progress has been made but a few things here and there. Picked up a known good used body harness to fix my wiring issues/damage. Got a weiand/lingenfelter intake from a buddy that will be getting sent out with my 799's for porting and port matching. Got a free low mileage LS2 cam from a coworker who upgraded so that will go in for now. 8.8 housing is sitting at my parents and just needs to go out to be mated to the 10 bolt. Hoping to have it running under its own power by Thanksgiving if everything goes as planned.
Old Nov 16, 2020 | 04:40 PM
  #40
AnnivSS's Avatar
Welp. Looks like its going to be up for sale before I even get going on it.
