Drag Racing Tech
Strange DA knob keeps turning.
Old Sep 25, 2019 | 06:27 PM
VandykeT/A's Avatar
Default Strange DA **** keeps turning.
To make a long story short my compression **** on my strange da was frozen so I sprayed some PB blaster and gently broke it loose with pliers and now it has no internal stop left or right. Will they still function the same or did I junk it. I can feference the **** position on the other side if internally it’s just a ball valve basically and each revolution just starts it over.
Old Sep 26, 2019 | 11:59 AM
MidwestChassis2's Avatar
My assumption is you are just spinning the **** and the shaft is not moving to make adjustments as needed. If you contact Strange they should be able to repair them/it for you.
Strange Engineering
8300 N. Austin Ave. Morton Grove, IL 60053
800-646-7618
Old Sep 26, 2019 | 01:57 PM
VandykeT/A's Avatar
The **** still clicks as it turns. I called strange and explained the problem and he said they’re a set screw at the ****. If that didn’t work send it in.
