Drag Racing Tech
Proper way to scale car?
Old Oct 1, 2019 | 07:59 AM
CB99SS's Avatar
Default Proper way to scale car?
Is there a write-up on the proper way to scale a 99 -f-body Camaro? I've read that you want the weight distribution to be 54/46. With my car at race weight, ride heights set even all the way around, anti-roll in neutral position. I had to add weight each side on the rear to get to 55/45 on weight distribution. This is how it ended up. I stopped adding weight to the rear until I make sure I'm doing this the right way.
LF 905 RF 788 55% Front
LR 681 RR 699 45% Rear
Total 3073
I want to make sure I'm not missing something and if there is a way to not have to add weight to the car. With out weight added I believe I was at 57/43 when I started.
Thanks
Chris
Old Oct 1, 2019 | 11:37 AM
JL ws-6's Avatar
Race your car!
That’s not that bad, I’d leave that and try it.
did You have a driver your weight sitting in the drivers seat, fueled up, etc?
Old Oct 1, 2019 | 12:10 PM
CB99SS's Avatar
Yes sir. I had the everything as it would set on the starting line.
