Proper way to scale car?
Thanks
chris
front to rear start around 53 pct front see what that gets you unless it’s making big power then 55 plus,
try to scale front as even as you can, left front will always (normally) be heavier due to right rear having more weight on it, this is ok.
set ride height first, the adjust shocks, ride height will change depending on where the weight needs to be. Leave it once it’s there.
make sure shock travel is where you want it as well. Depending on slick or radial and what type of conditions you will see will change that.
hope that helps
Guess what I'm saying is it's vehicle specific. IMO you should try to get the car level weight wise or as close to it as possible when it's stationary. Adjust suspension from there as needed to make it work. Without having the weight on wheels values for the car as its launching.... I don't see how one could ever calculate the perfect corner weights for a drag car launch?
In my situation I dialed in the car and what worked, then corner weighed. With the car setup balanced across the rear the car drove left hard. I had to drop weight from the pass rear to go straight. Which could be from a crooked chassis or 100 other reasons... Each car will differ in my experience.
Just my take...,
