Drag Racing Tech
Inconsistent ls1
Old Jul 6, 2020 | 08:28 AM
cmart40's Avatar
Default Inconsistent ls1
My 2000 firebird is the most inconsistent car I have ever owned. It will run up to 2 tenths off ? It has 3.42 gears,long tube headers cat and egr delete ,drag radials 165 degree thermostat and has had 2 different tunes by 2 different tuners.
I ran into someone with a similar car and they said they have the same problem, any help ??? could the knock sensors be retarding or advancing the timing ? can I disconnect. I run only 93.5 and can boost the octane if needed.
Old Jul 6, 2020 | 08:36 AM
MaroonMonsterLS1's Avatar
Auto Car or stick car?
If it has 3 pedals...it's probably your fault
Old Jul 6, 2020 | 09:09 AM
cmart40's Avatar
Sorry ,it is a 4l60e with shift kit.
Old Jul 13, 2020 | 06:28 AM
Johnny_M's Avatar
Do you have it tuned with Efilive or HPtuners?
You can make it consistent if you do.
Old Jul 13, 2020 | 11:10 PM
jhshnh's Avatar
What are your 60’ times? Do they vary or are the consistent?
Old Jul 14, 2020 | 06:19 AM
Johnny_M's Avatar
Turn off your torque limiters. Turn off the knock sensors. Mount the IAT sensor behind the front bumper. Get a WBO2 sensor. Its prolly on the lean side@WOT. Get an SD tune. Then your car will run consistently. Engine temp should be 180° every time you stage the car.
Old Jul 14, 2020 | 08:20 AM
conexion914's Avatar
I've fought inconsistency with my car and my wife's. Does it only happen in summer time? Are you able to look at your tune files?
Old Jul 16, 2020 | 09:24 AM
cmart40's Avatar
Thanks for the tips. I was concerned about the knock sensors.
 Michael S. Palmer
cmart40's Avatar
Yes, had 2 different tuners
