need help getting into 12's
Mods: slp lid, 160 themostat, slp 85mm MAF, slp cold air induction, 8mm MSD wires, LS1 edit tuning, slp y-pipe, manual fan switch, slp line lock, mac rear end girdle, 3.73 gear, star stage III clutch and that's it.
I usually run BFG drag radials, I have a set of ET streets that I have used once but didn't have the line lock so my burnouts weren't great.
what do you guys suggest I do (other than lose wieght <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> ) to help me into the twelves
my fastest time is in my sig. and last friday with the weather being 80 degrees, 83% humidity, and the bar. was 30.02 I was a milan witch is at 550 I think, I ran a best of 13.284 @ 106.xx with a lot of other runs in the 13.3 range
sorry for the long *** post
rok
by the way the 13.27 in my sig was with pretty much ideal weather in the fall on street tires, w/o the clutch line lock gear and girdle.
<small>[ August 22, 2002, 11:45 AM: Message edited by: Rok ]</small>
Take out your spare tire and jack. Remove your front sway bar. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
What rpms are you leaving at? Rpm shift points?
A line lock would help also. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
<small>[ August 22, 2002, 11:59 AM: Message edited by: Coach 02 M6 Z/28 ]</small>
The weight of your Hot Rod is way high. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Maybe you should take out your back and passanger seats at the track only. The great thing is you can always put them back in when leaving the track. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
You could also have the limiter set to 6,800 rpms and shift at 6,500 rpms this would help.IMO <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Coach
<small>[ August 22, 2002, 01:10 PM: Message edited by: Coach 02 M6 Z/28 ]</small>
Your set-up will get 12.99 or better with that HP and weight.
You shouldn't have to do standing burnout with ET Streets after they are broke in. Just hold at 6000, outside the water, drop the clutch, and clean them off and stage. I liked 15psi for easy launches.
Hold 4500 at the light, and release clutch quickly but don't drop it. Go to the floor with the gas at the third yellow.
Shift as high as possible. My best et's with a stock 2000 SS were done shifting at 6400-6500 with limiter super-high (never found it).
Start pulling on shift lever prior to shifting, it won't pop out. When you get to 6400, stab the clutch to the floor hard and release instantly. Since you are already pulling (pushing), it will pop into the gear instantly. You can lift the throttle quickly or keep it to the floor. Keeping it floored is quicker, but rough on the synchros.
You will need a <1.9 60' at that weight to get a 12.
You can do it!! Practice. Your car is fast, you just need to show it who's boss.
I have another question. before I had the new gear(3.42 to 3.73) and clutch I was netting 109 to 111mph through the traps know I'm around 106 what's up with that!
Change to worse gearing (nope)
Headwind
HP Reduction (either high temps, altitude, or engine)
Did you have a headwind?
You certainly will lose HP in the summer.
Is your engine running as strong? Bent pushrods in M6 cars are a common reason for HP loss. Did you do a 3-2 or 2-1 Upshift at redline since your last outing?
Might wanna shell out $50 for a dyno session to make sure your motor is putting out the numbers still.
If your motor is great, no headwind, then it's just weather.
<strong>IMO, spinning your car over 6000 is a waste of time. Id get an ASP pully, and go for headers also <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Have you tried shifting at 6400 yet? It was worth 0.2 on my car. Stock engine. No headers. Stock MAF. All smog in place.
The stock 2000 LS1 Fbody engine has alot of cam. Bone stock HP at 6250 is only 5 down from peak HP, and 6500 is only down 20 from peak.
Your powerband is the "fat" part of the curve, not the ramp leading up to it. You lose about 50rwhp by shifting at 6000 as you go into the next gear.
I lauch between 2500 and 3000 rpm with minimun wheel spin maybe the first couple few 5'max and then I hook without bogging,
shift points are as follows:
1st 5800 - have to because I hit the limiter otherwise
2nd 6200
3rd 6200
and ride out 4th
and my sixties do suck I average 2.08-10 with my best being 2.04
I also forgot to ad !EGR mod and TB bypass
<small>[ August 22, 2002, 01:05 PM: Message edited by: Rok ]</small>
90 deg., 93% hum., 30.02 barom., dew point 62deg.
so I think this fall with some better air I sould hit 12
rok
