Drag Racing Tech
shifting points
Old Aug 25, 2002 | 10:17 PM
ed f's Avatar
Default shifting points
I have a1998 z28 m6.current mods are whisper lid holly air filter,hpp3/flowmaser catback system,spec stage2 clutch assy,hurstcomp+ shifter,egr mod,ported air input throttle body,ram-air mod,msd sparkplug wires,royle purple syn-oil.the car has56,000 miles and appears to run strong.i was getting a great deal of wheel spin.i bought a pair of bf drag radials.my launchs were much better.my 60 time droped from 2.4 to2.1.my 1/4 still hung around 13.8-13.995.my top end speed was still around 103mph.at the end of the run i'm just going to 4th gear.what would anybody recomend for shift points/other mods.thanks for any help .
Old Aug 26, 2002 | 12:17 AM
mykdiver's Avatar
Default Re: shifting points
Well my mods are listed in sig, I don't understand why you are so slow. I have run 13.02 at 110 mph and I have alot less mods than you.
Are you power shifting, what RPM shift?
I powershift at 6000 I launch at 3000 dumping the clutch,on 14 lbs Nitto DRs, I bog a little then get going.
Hope that helps.
Old Aug 26, 2002 | 07:38 AM
ed f's Avatar
good morning,i seam to have a dead spot between 94 mph-100mph.the last time i ran the car was 8/16/02 and it was the first time i ran with the drag radials.i bought the car last dec.this past april i ran it for the first time.it was still cool outside.after a few friday nights,i was in the high 13's.then i started adding the mods.after all the mods were done.i had a traction problem.so i saved and bought apair of drag radials.
